theewarrior
just wondering if anyone has used other brand filter or have any cross reference #
smalltownpower
k&n 147 for phazer and 3 cylinder engines. 4 cyl engines have a different K&N number. k&n have a nut welded on the bottom and make it way easier to tighten and loosen the oil filter.
apex oil filters are kn-204
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
FYI, do not use the wrench flats for installing, only hand tight or you will be cussing later when removing. Even with the wrench flats it will be a beast to remove if used for installing.smalltownpower said:k&n 147 for phazer and 3 cylinder engines. 4 cyl engines have a different K&N number. k&n have a nut welded on the bottom and make it way easier to tighten and loosen the oil filter.
smalltownpower
ya i know, we bought yamaha oilfilter wrench, 15 nm torque
