Oil in airbox
Manogue
Age
32
Brown city
Rx1
Ok so my dads 06 Nytro has 17xx miles on it did a oil change everything was fine started it up 4-5 times after oil change and carbs cleans then after the that oil is pumping into the air box
Now the bottom hose is not kinked I see that that’s the big issue with most not the case here and if you take the oil cap off the valve cover you can blow through the little line
We removed the the breather check valve on that sits above the oil tank and put a tee there and started it up and no more oil in air box is that valve junk takes a lot of pressure to open the valve thanks for the help in advance!!
Sounds like that valve is stuck closed.
Yep we took the t off my rx1 parts sled and removed the valve and it’s all good werid this was is the valve isn’t stuck atleast when we were blowing in it
