markowinnipeg
Just noiticed today a couple of oil drips on my garage floor, took of belly pans and there is a small amount of oil in the pan? The oil filter is fine and looks like it might be running down from front of engine.
I know the oil level was a bit on the high side could this be blow by and if it was were would it be coming from?
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
it leaks out of the airbox and thats the only place it can go.
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
Yep, airbox. Either over full or it's been on its side recently.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Mine was like this too.. After my Cooke trip. It was on its side a couple times...
markowinnipeg
was not side but did have it leaned right over boon docking. I know it was above the full line when I checked. Are you supposed to check right after you shut it off? And do not screw in right?
Sorry new to the Nytro, used to just filling the oil jug..lol
markowinnipeg
Also took apart air box, foam filter was absolutely full of crap and you could feel the oil in it, looks like previous owner did not clean it in a while.
markowinnipeg
Ended up taking .25 of a litre out of the tank, now on H mark. Guess the manual is right when it says do not over fill
ScottyR
When it is overfilled oil will blow out the crankcase vent.
duhr8m
- Oct 27, 2007
- Minocqua WI
- sidewinder, SRXs, snow scoot + sport, vmaxs, enticers
oil
run till tank is hot to touch, idle for a couple min, then check with not screwed in. fill to full.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
If you never want to see oil on the floor again this is a must for ya all!!
http://fourstrokesolutionsllc.com/
It's the Jacobson roll over valve. Plug and play and a must for any boondocker or backyard mechanic
09nytro
If you ride hard or jump or boondock rolling on its side run oil between high and lownot scewed in then it wont leak in much or very little thats how i run mine and i got 5800 miles on it that way
markowinnipeg
Thanks seems to be good now that I droped it to the proper level. For $ 182.00 that roll over valve seems like a great idea, makes you wonder why Yamaha does not do this?
canoehead
- Jan 14, 2011
- NE, Alberta
Well I guess if they built the perfect machine their dealers would starve!!lol
