RX-1 Thunder
I have a 03 RX1. The only mods include a Bender exhaust and a Hauck stage 3 clutch kit. I am getting oil in my air box and am not sure where it is coming from. Is this happening to any of you guys? My dealer told me to cut a 1 inch slit in the big breather hose that comes from the motor into the air box. I guess it was an update for the 03's. The sled runs great. Punished a few F7's this weekend! Any thoughts?
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
It's normal with High RPM running. It's coming from the crank case breather tube.
RX-1 Thunder
Thanks. It sounds like it is normal then.
longshot
Oil in airbox
RX1 Thunder- curious, what is a Hauck stage 3 kit? Wts., springs, helix and gear change? Tx Longshot. Also, are you happy with it?
RX-1 Thunder
It just comes with a primary spring, secondary spring and helix. No weights and no gear change. I am pretty happy so far. It pulls about 3 sled lengths on a stock RX1. I really need weights though. It is rpming at 10,400 to 10,500. I think the exhaust is causing that.
