"OIL" ind wont go off
sooper
renfrew
So the big ole 2010 venture was on its side yesterday. Got things to fix but thats just check book type work. The oil warning on the LCD didnt do a thing right away. but 2.5 hours later it started. Just when I'm at a stop, and the oil level is fine. Thoughts on how to clear this code?
OK
Well is the check stick screwed in or just set in when checking? Any help?
the stick is just set in for measuring , did you look in the air box for oil ? , you could try turning off the light the same way you do when it tells you its time for a oil change , this step should be in your manual
Follow the manual procedure for clearing both the time to change and the mileage points for oil change.
I dont yhave either of those functions on my display
When you stop is when the message will flash. Check your manual for the procedures.
