I have a question about an oil leak on a 2009 Vector. Actually was riding with my uncles and both 2009 Vector's were leaving oil spots. One sled has 3K miles the other 6.5K miles.
We noticed the oil in the morning on the garage floor, it was leaking from under the front of the engine near where the back of the control arms connect to the bulk head. We took off the plastic and it appears to be coming from the air box breather area. We cleaned this off and went for a ride. 75 miles later the airbox had more oil & the sleds were again leaving spots on the floor. It was pretty cold outside around 5 degrees. They ran the sleds all last season and never noticed any leakage. All hoses are hooked up as far was we can tell.
It's wierd that both machines are doing the same exact thing. Is this something you guys see often?
