wayno
- Nov 23, 2005
Go back to page 3 and see how I repaired my tank. I have over 6000 miles on now and no more problems so far.
Bradford
Bradford said:pistons said:I might just take the lower mount out all together. It seems the tank is shifting back and forth causing the cracking. the hoses should stabilize it ok, and just let it dangle from the top grometed bolts. If there would be two mounts on the bottom, it would probable not crack.
I agree with this thinking. The top and bottom mounts bolt to different areas. If there is any relative movement between these two points or different vibrations, the tabs will be stressed.
I put grommets in mine and left the bottom nut loose. 6600 miles and counting
Brad
Bradford said:I haven't hit 8000 miles yet so the jury is still out on the grommet fix but so far so good
Brad
Just an update... I now have 16K miles on my original oil tank and still no leaks
Brad
Sno Cat
Has Yamaha resolved this on '12's & '13's? Or is this still an issue?
ragingrage
- Nov 10, 2013
Had this happen on my 05 rage at 22000 kms I'm lucky apparently, got a used one from my local wrecking yard and go the old one tig welded as a spare. Definately going to install the rubbers!
ragingrage
- Nov 10, 2013
jgustman
- Feb 25, 2005
- Cottonwood, MN
- '10 Nytro RTX
- Cottonwood, MN
Add me to the list, seeping only on '08 apex rtx with 5,500 miles, will look for cracks and fix what I've got from the looks of it and bitch to yamaha about it
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
We have an oil tank saver kit which utilizes rubber isolators to isolate the oil tank from chassis flex. Info can be found on our website.
Bradford
I thought I'd revise this thread again to see if cracked oil tanks are still an issue. I added grommets to my mounts when I first heard of the issue. 20K miles on the sled now and still no cracks
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
What year was the mount system on the tanks changed?
