Does anybody know what oil MPI uses on the superchargers? Is there other brands to use?
Ratpack
You need to get it from MPI or Ulmer. I don't believe anyone has found any other kind you can run.
kinger
I have a QT that I dont need, never used about a month old. Paid $140 for it would like $130.
Its very specific very expensive oil DO NOT USE ANYTHING ELSE.
SWENytro
kinger said:I have a QT that I dont need, never used about a month old. Paid $140 for it would like $130.
I think it's normal air compressor oil!? Both the smell and look is similar.
The function should be the same too!?
Or does anyone have any info?
machzrobbie
SWENytro said:kinger said:I have a QT that I dont need, never used about a month old. Paid $140 for it would like $130.
It is not normail air compressor oil - it has a special additive for the toothless gears - a friction ajent that runs between the gears to drive them. If you don't use their oil the gears will slip, causing lots of heat and burn the unit out! Save yourself alot of money down the road and buy the proper oil. Once you educate yourelf on ho the unit drives its self you ill understand and buy the proper oil - it does more then lubricate
stephenpen
It Rotrex Traction oil. You might be able to save some money if you can get it from a Rotrex dealer.
team ducktape
Rotex is from denmark - you should be able to order it dirctly from them. This would save you alot of shipping money.
Company details
Rotrex A/S
Herlev Hovedgade 17
DK-2730 Herlev
Denmark
Telephone: +45 7080 7005
Fax: +45 7080 7006
VAT Number: DK 25381238
Deliveries and pickups: please go to gate Ø2
Office hours: 8:00 - 17:00 (CET)
Company details
Rotrex A/S
Herlev Hovedgade 17
DK-2730 Herlev
Denmark
Fax: +45 7080 7006
Was in contact with a danish company, but Ulmer Racing delivered it to me FAST. Have been doing some testing with the MPI and the power and the response i amazing.
stephenpen
Whats the easiest way to prime the blower after an oil change ?
yooper1
I've used a air hose to pressurized the system through the oil tank, turm your regulator down to about 15 psi.
347strokin
stephenpen said:Whats the easiest way to prime the blower after an oil change ?
Glad you asked, Im just about to do my first oil/filter change on my Ape.
