Oil on MPI supercharger
Cilius66
Norway
Does anybody know what oil MPI uses on the superchargers? Is there other brands to use?
You need to get it from MPI or Ulmer. I don't believe anyone has found any other kind you can run.
kinger said:
I have a QT that I dont need, never used about a month old. Paid $140 for it would like $130.
Its very specific very expensive oil DO NOT USE ANYTHING ELSE.
I think it's normal air compressor oil!? Both the smell and look is similar.
The function should be the same too!?
Or does anyone have any info?
It is not normail air compressor oil - it has a special additive for the toothless gears - a friction ajent that runs between the gears to drive them. If you don't use their oil the gears will slip, causing lots of heat and burn the unit out! Save yourself alot of money down the road and buy the proper oil. Once you educate yourelf on ho the unit drives its self you ill understand and buy the proper oil - it does more then lubricate
It Rotrex Traction oil. You might be able to save some money if you can get it from a Rotrex dealer.
Rotex is from denmark - you should be able to order it dirctly from them. This would save you alot of shipping money.
Company details
Rotrex A/S
Herlev Hovedgade 17
DK-2730 Herlev
Denmark
Telephone: +45 7080 7005
Fax: +45 7080 7006
VAT Number: DK 25381238
Deliveries and pickups: please go to gate Ø2
Office hours: 8:00 - 17:00 (CET)
Was in contact with a danish company, but Ulmer Racing delivered it to me FAST. Have been doing some testing with the MPI and the power and the response i amazing.
