Lou's rage
Hello to you guys ! Question ! Can anybody tell me if there is a hole (plug) in the 3 cylinder RS where I could insert my sender unit for my oil pressure gage ? But isn't there a low oil pressure warning idiot light already on those motors ? I beleive there is ???? So then where would it be located ? Thanks ahead ! Lou's rage !
Lou's rage
Hi again ! Ok , not to many replies hey ! Another question than , does Yamaha sell an adapter between the oil filter and the motor where a sender unit could be screwed in ??? Need my gages !!!!
Lou's rage
Hi aVenture ! I will try to locate that bolt , I believe it is in the front of the engine slightly under the head ? I would of thought the oil pressure would be approx. ? 30-40 lbs !!! 6 lbs is not a whole lot for pressure ! But hey , if that's what it calls for , let it be !
Thank you so et a la prochaine , on se reparle ! Louis
