twiz28
- Nov 8, 2004
- New Brunswick, CAN
- 2017 Sidewinder BTX 1.75 Backcountry
2017 Sidewinder XTX 137
About to fill the oil tank, how much oil above the normal requirements is recommended to compensate for what will be going through the turbo? MCX 180 kit.
Just fill her up and check the dipstick as you fill, when its at the normal level, start her up and let her idle for a minute or two, shut down and let it sit for a few minutes, check dipstick and fill up to correct level.
Start her again and let her run for a couple of minutes, shut down and check the dipstick after a couple of minutes, your level will now most likely be just were you left it, but if not just keep repeating the procedure until it is correct.
Keep an eye on your bottle tho, the Nytro takes around 3liter.
twiz28
- Nov 8, 2004
oil
Usually takes just over 3 liters, was just wondering if you needed to add more because of the oil lines, was expecting to need a few hundred ml more.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
The oil lines and the turbo does not take much.
X2 - kimoajaj
X2 - kimoajaj
