black knight
My oil tank seams to be weeping along the seam at the bottem right side, right near the mounting bolt.
Anyone have this happen and anyone try running a bead of weld along the seam?
Almost 18,000km on it
BK
BK
This is a common problem. I have not heard of people welding them, but others will chime in.
machzrobbie
They can be welded, have had to do a couple of them
Honk
Same place as mine, a shot of jb weld works well.
rc2ubro
had mine welded, make sure to weld front side, and backside of crack. two years, still holding. oh, i also put rubber washers under mounts for a little vibration isolation.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
machzrobbie said:They can be welded, have had to do a couple of them
X2
black knight
Got my oil tank off. Pluged all the holes and pressurized it and its weepping at the corner in between the pencil marks on the front and back.
When i clean the oil off it takes 10 to 15 sec. of pressure before any oil starts to weep.
Do you guys think J.B. weld will do or some weld weld. I have a 40X magnifien glass and when theres no oil you cant see any sign of a crack or hole on either side but when i put pressure on it , it starts to seep.
Thoughts would be welcome.
BK
BK
Sled Dog
I would not jb weld it for the simple reason of hot and cold will eventually cause the jb to fail. Take it out and weld it.
DUTCH OVEN
Get a hold of the Mod Father in Orillia Ont, he sells oil tanks for 150$
DV8
You can have it welded for way less than 150. Take it off and weld it.
sherlock29
yep take to a good welder.. will need to be tig welded. walls are very thin...
