oil useage on apex/attak
SharkAttak
East Falmouth, Ma.
i noticed after running 2000 mi., i was down about 3-4 oz. in oil is that normal, do the apex/attak suppose to use some oil?
yes that is normal,yammi notes that you can use up to 1 qt. per 1,000 miles so if you are under 2 qts per your 2,000 miles you are fine.
really a quart per 1000 mi., wow, i would think that would be a lot, i thought having to add 4 oz. was alot
Just for fun read this thread
Some guys have found out that they are not really using any oil.
But the deal is, dry sump oil systems make it tricky to get accurate oil level readings.
On my last oil change, it used 1/2 quart for 3200 miles. I find this very acceptable.
Tal said:
Hey TonyVT and all - how did you break yours in?
Did any of you with low to zero oil usage break in your motor per motoman, (http://www.mototuneusa.com/break_in_secrets.htm),
or per the Owners manual?
I bought mine used 4 months old with 1900 miles. I dont know how he broke it in. He was a real neat freak tho... his garage was cleaner than my house.. he builds race cars so I figured he knew what he was doing...
