Hello all!
As in my name it pretty much gives it away i have an rx1, enjoy the machine for the little that i have had it,
The question i have i know has been covered quite a bit on this site but the only thing about that is the postings and threads are a few years old and was just looking for a quick update.
i notice many looking for a cheaper alternative to yamalube because the price is rediculous, i have read of ppl using mainly 2 types of oils Mobil1/ and Amsoil 30 weight.
so now over the years how has this oil treated your machines? anyone found any negatives or are satisfied with these oils? i was convinced on mobil 1 30 weight when i read in a few places that all in all it is still made for a vehicle and cannot produce the 100 percent high rpm lubrication we need.. yet, i hear ppl that switched to Mobil 1 and never looked back.
The other day i found out about Mobil 1 European Formula 40 weight, supposly this oil is of higher grade and will lubricate well for the high rpm engines, but again doing info searching and calling around it is stated its not meant for Wet clutchs, plus 40 weight when the machine calls for 30.
so what do you guys think that have used other than Yamalube, if i was to go Mobil stick with 30 weight, or go for the advanced 40 weight?
