newfie09xtx
- Jul 13, 2011
- Corner Brook, NL
- 2016 Polaris Switchback 800 Pro S
My xtx has factory bushings still in and has approx 3000 km, so I probably going to be changing them. Yamaha has them for 79.95 SMA-8GLFR-KT-00 and ulmer has them for 75$. Is there any difference? Ulmer also Ski bolt bushings as well, if these need to be changed too I will get them from ulmer but if not I will most likely go with them from yamaha (save me shipping etc...) Oh I put 6.9 pilots on last year so I had to reverse the bushings.
Not much diffrence.The supplier for yamaha copied ulmers bushings.I would go with the original designer.
newfie09xtx
- Jul 13, 2011
- Corner Brook, NL
Do I need to change the ski bushings?
Only if sloppy.
judger101
its nice to support the smaller guys if possible.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
The OEM ski bolt bushings in the spindles wear out fast (not the ski bushings that you reversed in the Pilot skis). Replace them with Ulmer's bushings or spend a little more and go with UP bushman's stainless steel kit: http://www.ty4stroke.com/viewtopic.php? ... ht=bushmen
- 75K
