yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I removed the snorkel from the side panel that was directing air to the clutch! to hopefully get cold air to intake!! What do you think...bad idea?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Just went for a ride to test
+4 c outside and intake temp was 32c
28c difference from outside temp
Is that normal or better?
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
did not make much difference on mine. This does however make a great difference. Outside temp is now the intake temp.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Haha I wanna do the outside intake but I'm being a scared bitch..lol to cut cab!!!
Is it a big enough difference to do it???
I was looking at side and the extension tube for intake and I looks like I can go threw side panel instead off cab
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
did not make much difference on mine. This does however make a great difference. Outside temp is now the intake temp. View attachment 125920
X2
savageman69
- Apr 21, 2014
- 2014 arctic cat zr 7000 limited
outside for sure...way colder and looks so good...just cut the black slotted vent area.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Just like InRBigness and yamahaguys, mine is outside and the temps are usually within a couple degrees of outside air temp.
Just do it already
Just do it already
chuckpp
- Mar 27, 2013
- Belmont N.H
- 2016 Yamaha srviper ltx dx
My right side is open like that from new should there be something there?
Sent from my Pixel using Tapatalk
Sleepingkitty
- Sep 9, 2015
- SW Ont.
- 2015 ZR 7000 El Tigre with a little boost
It makes a huge difference in intake temps. Don't go through your side panel, it will be a pain every time you take the pannel off. As mentioned above, go through your black vents. I just slowly took material away with a dremel tool.
yamahaguy
Ride SAFE
- Apr 20, 2014
When your done cutting and trimming it will look something like this.
millstreet
- Dec 6, 2005
- doylestown, pa and old forge, ny
- current - 2018 Sidewinder ltx-le 50th
Or this;
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
ok I did it!!! it hurt but it's done..lol
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
i'm going to clean it up the next time I remove the hood!!! and frogskin around pipe!!
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Yes the logo is on back side I took pictures while installing it's turned now ..with logo facing outDidn't your MPI kit come with a Frog skin type sock for your air cleaner?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I was talking about cutting out the rest of the black plastic vent I cut to pass intake threw and putting Frog skin in the opening around the pipe in the vent opening
