onestopjim
TY Advertiser
- Feb 22, 2006
- Howell MI
- www.onestopperformance.com
With the use of STM KOT sled, and lots of hours we got this 2 stroke standalone up and working, this is the next step to running big boost and big turbos, with safty features OVER BOOST, OVERHEAT, OVER REV,
also has the best 2 step available the user is able to just set RPM you can set how the limiter is configured starting points, and ending points in TPS and fuel and timing while you on 2 step,
also has a launch table to control starting line boost , output for external boost controller
the data logger a lone is worth the money you can data log every thing you can think of,it like have Dyno on board .
this ECU is MAP based so when you lug down your 2 stroke on boost you will not DETO
this system is going to allow you to run more safe and reliable boost.
Now that we have this up and working this will work on any 2 stroke 2 cyl 3 cly or 4 cyl with or with out boost.
we will have pricing on our web site,
come next is Z1 standalone system this will be for the big turbo guys that want BIG HP and a adjustable 2 step should be out in 2 weeks.
Heres a clip, Mark dynoed before we installed system and after, with the standalone made more power at same boost and lazy tune.
http://www.youtube.com/watch?v=Gyyh4Y5FZvk
Jim
OSP racing builds the quickest race sleds 7.39 182 mph in 1/4 asphalt 4.43 152 mph in 660 ice 3.76 143 mph in 500 grass 189.47 1/4 mile ICE speed run 172 in 1000 feet ICE 1st sled in the 3's in 500 ft
OSP 4.43@152mph in 660 and other OSP Racing YouTube VIDEOS
Jim
