OSP grass sled update with Standalone SEFI
can make close to 500 hp but would be short lived we use 450 and can run for ever.. what I do to motors is not that costly if you send me a motor for 6000.00 you would get what I use, thats with all new parts, rods, pistons, bearings gaskets. must have a good block and crank. head
and you could have the same motor I build for my self,
And 6000$ is not costly if you ask me ;)
My motor cost my twice that and probalbly will never see more than 400hp.... I probably went a bit overkill :-o
is that cost for the efi motor or just motor very impressed with how fast that thing spools up crazy fun.
That cost is for motor mods only and rebuild, NOT efi system
THIS EFI / ignition system is 5000.00 with all parts, coils, wiring harness, triggers, sensors, injectors, fuel rail and fuel reg. REMEMBER this has O2 built in, and data logging that records 52 times a sec.
I will put up a video soon on the data logging and TRACE feature
Was about to go with rb3 thing.... and now that crazy sefi thing!!!
Ahhhhhhhhhhh with high energy ignition.... a must for higher boost.. (at least at sea level like us where we make more real life hp and cyl pressure!....)
Things never cease to get better and better! :Rockon:
