onestopjim
TY Advertiser
- Feb 22, 2006
- Howell MI
- www.onestopperformance.com
thanks its working very well so far its raining here so might be 1-2 weeks before we get to the clay track and make full passes
http://s299.photobucket.com/albums/mm30 ... 2f91ac.pbr
4strokes are better than2
what kind of hp are you making & what is one of your motors worth just out of curiosity.that motor sounds nasty very nice
onestopjim
TY Advertiser
- Feb 22, 2006
- Howell MI
can make close to 500 hp but would be short lived we use 450 and can run for ever.. what I do to motors is not that costly if you send me a motor for 6000.00 you would get what I use, thats with all new parts, rods, pistons, bearings gaskets. must have a good block and crank. head
and you could have the same motor I build for my self,
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
onestopjim said:can make close to 500 hp but would be short lived we use 450 and can run for ever.. what I do to motors is not that costly if you send me a motor for 6000.00 you would get what I use, thats with all new parts, rods, pistons, bearings gaskets. must have a good block and crank. head
And 6000$ is not costly if you ask me
My motor cost my twice that and probalbly will never see more than 400hp.... I probably went a bit overkill
is that cost for the efi motor or just motor very impressed with how fast that thing spools up crazy fun.
onestopjim
TY Advertiser
- Feb 22, 2006
- Howell MI
4strokes are better than2 said:onestopjim said:can make close to 500 hp but would be short lived we use 450 and can run for ever.. what I do to motors is not that costly if you send me a motor for 6000.00 you would get what I use, thats with all new parts, rods, pistons, bearings gaskets. must have a good block and crank. head
That cost is for motor mods only and rebuild, NOT efi system
THIS EFI / ignition system is 5000.00 with all parts, coils, wiring harness, triggers, sensors, injectors, fuel rail and fuel reg. REMEMBER this has O2 built in, and data logging that records 52 times a sec.
I will put up a video soon on the data logging and TRACE feature
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
onestopjim said:4strokes are better than2 said:onestopjim said:can make close to 500 hp but would be short lived we use 450 and can run for ever.. what I do to motors is not that costly if you send me a motor for 6000.00 you would get what I use, thats with all new parts, rods, pistons, bearings gaskets. must have a good block and crank. head
Was about to go with rb3 thing.... and now that crazy sefi thing!!!
Ahhhhhhhhhhh with high energy ignition.... a must for higher boost.. (at least at sea level like us where we make more real life hp and cyl pressure!....)
Things never cease to get better and better!
- 11K
