Windernation
- Sep 24, 2017
- Mn
- 09 Nytro
17 Sidewinder btx se
I have a 2017 sidewinder mtx with hurricane 270 tune. The sled recently started hitting the rev limiter. Checked everything over in the clutches and everything looks good. The 270 tune is suppose to run 17.5 psi and when I give it full throttle it hits 19 psi then levels out at 18 and the knock sensor start flashing a couple seconds into full throttle. I checked the sled over for loose hoses and used sinch wired on the ones on the waste gate actuator and hose claps on some of the big ones. Any ideas what it could be or what else to check? Thanks
Your blowing out the track and over boosting, maybe you need more weight in the clutch to hold it back.
Windernation
- Sep 24, 2017
- Mn
- 09 Nytro
Added more weight to the clutches today. It kept the sled off the rev limiter but it still ran 18.5 psi and knock lights flashed at full throttle
who’s clutching?
Windernation
- Sep 24, 2017
- Mn
- 09 Nytro
Stock clutches with dalton weightswho’s clutching?
I would contact Dave at Hurricane
Brett Allen
- Oct 5, 2019
- Sagle, Idaho
- 2018 Yamaha Sidewinder MT-X SE 174, Ice Age Elevate, MCXPRESS stage 3, Earth X Battery, TKI Belt Drive, Stingray Mods Clutch kit. Apex primay, Nytro secondary.
Also check clamps at the head holding the boots that go to the throttle bodies, could be loose letting boost out and creating the knock light.Stock clutches with dalton weights
Climbmax
Don't believe every boost gauge either. Get a good liquid filled one that you can zero.
