mobile
- May 24, 2006
my son has a 2002 grizzly and this weekend it over heated and he had to add some water but we were working it pretty hard and it was 95+ outside and i thought it was just because it was so hot but i hooked the disk to my 2004 griz and did not have any problem. is there something we need to do? flush it out or replace the antifreeze maybe? thanks for any info.
SledderSteve
- Apr 23, 2003
- Orange County California
- Rental
It's likely the radiator has become plugged with time and splashing through mud puddles. You don't have to be 'boon-docking' to plug up the tight fins on a Grizzly radiator.
Remove the front rack then the access panel on top of the front fender to get a view of the radiator and you will likely see a collection of dirt and gunk collected on the rear of the rad. Simply use a hose to wash out it out from the rear and you should be good to go. Avoid using a pressure washer as it can bend over the fins and you'll be plugged for good.
Hope this works for you.
shanksRX-1
- Feb 6, 2006
- Pennellville, NY
- 2010 Apex
- Pennellville, NY
I think steve might be right. Also it won't hurt to change the coolant its probly do. One more thing since his is an 02 has it had the updated side panels put in with the vents in it. I have a friend that has an 02 and his overheated alot until he got the side panels with the vents in em like the 03 and up have.
hope this helps...
hope this helps...
SledderSteve
- Apr 23, 2003
- Rental
Good call on the side panels, I had forgotten all about those on that model year.
After posting the above, I decided to practice what I preach and sure enough the back side of the rad on both of my machines was starting to become plugged. With a clear view from the top, I could see that water sprayed from the front through the grill was not getting through the rad. A quick blast from the hose on the back side was all it took to knock off the grunge and get flow again.
The best part is that it only takes a couple minutes to do this while my Sportsman riding friends seem to take at least a 6-pack to do theirs.
Maybe they like it that way.
I 2nd that
grizz 5
- Aug 16, 2004
- muskego,WI
- muskego,WI
- YAHOO
- atessman
so depending on how many sportmans you ride with ,you could be drinking a lot of beer
lol
lolGanz
- Jun 5, 2004
- Deerfield Wi
- Deerfield Wi
That is one reason I like the fact all my riding buddies have Poo's!
Tom, we need a beer drinking emoticon on here
SledderSteve
- Apr 23, 2003
- Rental
All this while I thought I was pregnant and it was just all that Poo.grizz 5 said:so depending on how many sportmans you ride with ,you could be drinking a lot of beerlol
Ganz
- Jun 5, 2004
- Deerfield Wi
- Deerfield Wi
"All this while I thought I was pregnant and it was just all that Poo."
Good one LOL
Where you get the beer emoticon?
Good one LOL
SledderSteve
- Apr 23, 2003
- Rental
Ganz said:Where you get the beer emoticon?
Click the "View more Emoticons" link at the bottom of the Emoticon window and you'll find some more.
:rules
Ganz
- Jun 5, 2004
- Deerfield Wi
- Deerfield Wi
WTF?, I did that. I must be friggin blind.
Or I just need a few more
LMAO...come on get with the program
Ganz
- Jun 5, 2004
- Deerfield Wi
- Deerfield Wi
Once the beer goggles are on I can see REAL GOOD........
