over the summer mods??
mike,
didn't get a chance, ran out of snow too early this year.
i did adjust my secondary to the mtx setting though & will see how that does. i didn't have any problems with ulmers clutch (no weights) & b2 secondary if i remember right.
I received and put on my LakeEffect riser last night, Chris is a great guy to deal with!
Lets see some pics! I am very interested in Lake Effect but have not herd back from them yet.
Will take pics tonight and try to figure out how to post tomorrow
another turbo phazer has popped up for sale here. a 07 gt for $5000 seems a little cheap no pictures too bad cause i want it. but stock phazers are selling here for 5000 which is odd for a turbo
would like to change the skid frame to look like this. might save the hy fax as well.
Update -- I shouldn't be allowed near wrenches. As I was pulling the handlebar up to bolt it onto the Lake Effect Riser, something snapped, sounded like it was just a zip tie. Now I'm getting code 84, so it looks like I pulled some funny business with my throttle cable. Haven't had the patience yet to tear half the snowmobile apart to see exactly where the throttle cable hooks into...
Things are never as easy as they seem, or "ten min jobs", lol. This is why dealers get paid the big bucks, they can do it in 1/4 the time.
plans are to upgrade rear suspension new fox zero pros are on way with stiffer spring also some cold air intake pods to try. next will try rear bigger wheel kit and x click blok to stiffen up rear springs.
I pretty much did the same thing. Just start removing stuff to chase the throttle cable down - pretty straight forward. Just below the bracket that holds the cable bundle is a boot over the throttle cable, roll that back and out of the way, under the boot is an adjuster. My cable pulled out of the top of that assembly. Real hard to get back in the jacket does not want to go in. I trimmed it back, put some tape on it and was good to go. I had to route the throttle cable out side of the steering column to get it to work.
All good and riding after though.
It might also be the little metal clip that holds the throttle cable at the thumb throttle. If its not seated properly it "clicks" and throws the 84 code. I had to re-bend the clip to "catch" the throttle cable and I haven't had a problem since.
Or the throttle cable is too short and you will need an extension.
Cubby said:
It might also be the little metal clip that holds the throttle cable at the thumb throttle. If its not seated properly it "clicks" and throws the 84 code. I had to re-bend the clip to "catch" the throttle cabl;e and I haven't had a problem since.
I started my fix at the thumb end and ended up chasing down hill. I put on the Lake Effect 2 or 2.5 (forgot what the exact rise is) riser and did not need an extension (did have to reroute though, not obvious until you swing the bars completely side to side).
