spike337
What color is your 'FX'?
Blue and Black, I'll take pictures of it when I get off the trail later on today
Here are a few I had my on HDD
That is the base model phazer, not the FX. Can tell by the front shocks, straight bars (FX has hooks) All FX's and GT's have reverse, not available on base model I believe. '
So, for the fan, you can replace the entire wiring harness, or wire in a switch and run it off your battery, or you can get fancy an install a relay, but if you get a properly rated switch, not really necessary.
spike337
That's why i asked, it wasn't adding up. Is there just blue plastics on a base? Or did they offer it that way?
Nice sled though. Personally, i'd do the direct wiring with a switch. The harness has to be a small fortune? Plus the install can't be easy.(harness install)
- 12K
