aceltx09
What are you guys using for oversized bogie wheels. Part numbers would be great and how long have you been using them, I'm worried about cracking the rails thats why I haven't tried them yet. I was bery happy with my hyfax first half of the year,2nd half very unhappy 2 sets of slides
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Were are the wearing down at. For me I just add a set of stock wheeels and mounts and something to kick up snow. I had put lager wheels on my apex mtx and crack the rails
rindtj
Did you put oversized wheels inside and out?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
rindtj said:Did you put oversized wheels inside and out?
On the inside that way it would not hurt me when laying the sled on its side.
Super Sled
- Feb 25, 2009
- Summit X
Scratchers are a fantastic idea for saving sliders. IMHO work better than larger wheels, if you can find a good place to mount the scratchers and get a good snow spray back onto your skid. I use both ski scratchers and Slide Kicks cable scratchers.
But lots of guys are running largert wheels too. Cracking a rail or loosing a wheel are possible ramifications of doing this because you are effectively removing a lot of the weight off of your sliders and transferring them to wheels instead. Thats a lot of load/ stress onto the wheels, the bearings, the mounting hardware, and ultimately also the rails. However, many guys run large wheels and all they suffer from is less slider wear. But anything is possible out on the trail (Or is Apex 06's case, out in the trees I bet ;-) )
There are lots of options out there for larger wheels. Excell X wheels, Ski Doo or Polaris wheels with mounts to fit our rails, Standard wheels with an off set mount like Pioneer sells are just a few options.
apex55
http://www.shadetreepowersports.com/cgi ... idler.html
04-053-3 is the part number from link above. Wheels and bearings are a little wider also. I replaced 4 outside and 2 inside. Had to remove about 3/64 off the inside mounts to keep the wheel in the center off the track lugs.
- 19K
