PCV LCD 200
Joshua
Newfoundland
Canada
2018 Yamaha Sidewinder BTX LE 50TH
Is anybody running the Power commander 5 with the LCD 200 setup? I'm putting a turbo kit on my Viper and I want to use the LCD display instead of the gauges. Are there any pro or cons with this setup? I'm only concerned with displaying A/F and Boost.
I tried two in a row. Screens would freeze like an old phone. Worked only when above zero.
Nope. Just every time you stopped you wanted to unplug it and put it in your pocket to warm it up. I had one get moisture in it, and one dry, but both froze.I bought a yamaha handlebar pad. Cut a rectangular notch in the face/top of it. Then flush mounted it into the pad. Hoping the foam around it would help with the temperature, and weather. It also made it stealth looking. See the pad in the picture.
I have run the LCD screen for the past few years and it will sometimes reset its configuration when cold and its really hard to read on the trail.... just my 2 cents.
Lcd 200 is junk stick with the gauges like I am.
I run mine in summer temps 80 and about every day or two ya have to recalabrate it Pain in the arsh . I would have to agree with rayone02
