PCV Tuning
FLYBYU
south elgin, il
Ok so I think I have the map pretty close. I Talked to a couple PCV guys today and just wondering what others think also. So obviously we have no snow in Illinois so i'm trying to set map on stand and the problem i'm running into is autotune keeps trying to put fuel in 6000 to 7000 rpm range on trim map and I can't seem to stop it. As one person I talked to today mentioned as I was thinking it also is since it's on a stand with no load and making 0 boost is that autotune is dumping fuel in the trim map to try to make afr right. But since there no boost and if their was, the pcv would be adding fuel there based off boost pressure. I'm confusing myself talking about it. So if i'm making boost and i'm in that rpm range which I know it's making boost at, it will add fuel based off boost pressure and not so much in the trim map. Does this sound right? It makes sense somewhat, just sucks I have to go on first trip just to tune.
You cannot build a map on a stand....your motor is not under load.
