Yamaharider74
- Dec 23, 2013
- theodore,saskatchewan
- 07 Yamaha apex
Yes
yes they are definatly a work in progress these machines lolIm not happy with mine yet. Mine has stock injectors.
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
good morning how is your map for the 5-8000 rpm range mine is perfect at wide open throttle now 10.7afrbut the mid range is is 13-14 afr like about 1/4 to half throttle but when i crack it open its good the afr ,now would i adjust the fuel or the throttle percentIm not happy with mine yet. Mine has stock injectors.
I just have not had the time this year so far to ride it or work on the map, sorry.
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
No problem ,just lovin the boosted sled the more I work on it the more I learnI just have not had the time this year so far to ride it or work on the map, sorry.
Apexboon
- Jan 18, 2015
- 2006 apex gt with boondocker side mount. GT28
Can you email me that map?Here is an apex PCV map.
Apexboon
- Jan 18, 2015
Where do I download maps, new on here and can't seem to see those maps above. Wanting to get or buy a good map for 06 apex turbo with pcv.
Just click on them and safe them to your desk top.
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
hi did you ever get your apex up and running properly as far as the map, ,and if so would you share a copy of your map also what are you running for weights in your primary clutch thanks its time to start working on my sled againI just have not had the time this year so far to ride it or work on the map, sorry.
Im going to make a few more changes and Ill send it over.. its still needs some work.
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
Ona
Okay sounds good thanksIm going to make a few more changes and Ill send it over.. its still needs some work.
I am interested in your map as well...I am in the process of trying to build one for my Apex.
Stage 2 - 18lbs boost
PCV with PTI
Ignition module
Auto Tune
450cc injectors
I am having to pull a lot of fuel out in the lower RPM/throttle positions as it was way too rich
I am thinking of going back to stock injectors
PCV with PTI
Ignition module
Auto Tune
450cc injectors
PCV with PTI
Ignition module
Auto Tune
450cc injectors
I dont have the new PTI Version, I have a Pressure Sensor add on , before the PTI version came out.
OK thanks
OK thanks
Ulmer might be able to set you up with a different map for starts that has pressure tables that work with the PTI
Allan has been helping me with this sled already and I am thinking of bringing him the sled to tune as any map I have tried has not hit the mark.Ulmer might be able to set you up with a different map for starts that has pressure tables that work with the PTI
