porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
LMAO!
Good luck getting it by her
yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
can you ask if they work better with raised compression engines please.
the boosted guys drop compression were as us trail guys it is very easy to raise the compression.... so maybe we would for once see some gains
Beenba
- Feb 16, 2011
- 2009 Nytro XTX
I really doubt they picked up 6hp just from changing to different coils. Usually you only need a stronger spark when running a super rich AFR or boost (in which case has both). Most guys just close up the spark plug gag to prevent blow-out and bogging.
I just have a hard time seeing that running these (and I assume running a wider gap - where the real power comes from) helps that much. But you never know, dyno's don't lie but I wasn't there...6hp variations can be very common just from IAT temps.
If I was boosted 20+psi running 10.5AFR...i would consider them. My $0.02.
yukon yamaha
- Jan 30, 2008
any updates on the coils? has any one ordered a set for their nytro or viper?
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
I will prolly be getting a set as it gets closer to winter, as they said a 30 day money back guarantee, so im waiting till it gets closer to riding season.
yukon yamaha
- Jan 30, 2008
awesome!
please keep us in the loop, If you have a good review I will be getting a set for the viper and nytro
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
will do yukon!!
