Studroes144
- Oct 30, 2013
If I ease into the throttle it will let the sled go past the stock limiter and work fine. If I stab the throttle it will hit the limiter wherever I set the rpm takeover which is odd. It worked fine before I added the turbo and I have another stock sled that it works fine on all the time. I only added the turbo late in the year so I didn't have too much time to test. I will keep testing this winter.
Are you using the pcv pti?
DC5
Yes, sled runs great otherwise
Studroes144
- Oct 30, 2013
Are you using a stutter at all? If so how is that working?
DC5
Yes I am, seems to work good but haven't done a lot of testing yet
Studroes144
- Oct 30, 2013
Are u getting it to build and boost when it's on stutter? Or is it just zero or vacuum?
DC5
I had it building a little boost but will play with it more this winter
Studroes144
- Oct 30, 2013
Great that's good to hear, I have the pcv pti and ignition module waiting to go on and doing the stutter too, just gotta wait til it gets colder to get it on the dyno and tune it.
- Apr 14, 2003
- Hessel, Michigan
I want it for the rev limiter increase so I can clutch the sled better and utilize launch control.
machzrobbie
Its alot easier to build boost on pump gas in the winter with the stutter but without timing control while on the button it is harder to control
Do you mean around 8800 ?? where it "grabs" the signal??
DC5
Yes, but I can change the takeover rpm and the limiter seems to change with it. It's odd because it works fine on the stock sled.
machzrobbie
I had the same problem with my turbo apex last year, I tried pcv, pciii and rev xtend wouldnt work. I have both working on my stock sled, and I changed ecu, harness and everything and still wouldn't work on the turbo, put it all back to my stock sled and it worked fine.
Armani
- Dec 25, 2014
- Norway
- Viper 2015 MTX 270 MCX Turbo
Is it only the pcv PTI version that making problems with boost and rev limit , and no problem with only pcv/ign module with higher rev?
YamahaFreak
The Pen is Blue
- Nov 26, 2009
- McHenry, IL
- Sr Viper XTX SE
What RPM's is everyone at when Stutter(2-step) ?
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
2800 hereWhat RPM's is everyone at when Stutter(2-step) ?
- Apr 14, 2003
- Hessel, Michigan
2,400 2-step, engagement 2,550-2,600
