Rodmax
- Feb 18, 2019
- g4t 6c4
- Yamaha phazer 2010
When I start it , it takes off , will go 20-30 km/h without touching throttle, but throttle still works.
only issue that happened is that the wires on gage were pulled out and some may have grounded together, I am trying to get all connected up again but still the high rpm when started up.
Where should I start???
CCCT
- Jan 9, 2017
- Barrie/Sudbury/Muskoka
- 2007 Apex
2009 PhazerGT
weird - I'd start by turning the screw to adjust the idle, maybe something with wonky with that. Fire it up on a stand then turn lefty, its located through hole by left A arm. I put a picture somewhere not far back.
2stroken
You can put the display in diagnostic mode and check out the throttle position sensor.
CCCT
- Jan 9, 2017
- 2007 Apex
2009 PhazerGT
Even better. I'm a phazer newb so listen to the other guys first.
ATV PRO #11
- Jan 22, 2011
- Garson, MB, CANADA
- 2014 Yamaha Phazer XTX
Start up here I’m at 22-2400 rpm.
Is your red light on when you start it?
Is it all warmed up and still Reving high?
Your idle adjustment is above your a arm on brake side of sled. Round plug. Pull out and use Phillip’s to adjust. Counter clock to lower rpm.
ATV PRO #11
- Jan 22, 2011
Re reading , that that’s gotta be 5000 rpm idle or more to engage primary and get you moving when started up. That’s abit scary.When I start it , it takes off , will go 20-30 km/h without touching throttle, but throttle still works.
Rodmax
- Feb 18, 2019
- g4t 6c4
will try the diagnostic mode thing tomorrow!!
Rodmax
- Feb 18, 2019
- g4t 6c4
Throttle position at 25 relaxed and 98 full throttle,, idle rpm at 2800 when I touch throttle it goes 5600 rpm..
Can I fix this just by turning down the adjustment screw??? found the hole where the screw is supposed to be, I have to go deeper to find it...for some reason it is not where it should be...
This sled just did this , last week ran fine idled normal, just progressively started idling faster!??
Thanks, Rodney.
Thanks, Rodney.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
You'll have to adjust the throttle position sensor to within spec. Closed, it's supposed to be between 15 and 18 so at 25, you're way out of spec. Adjust it down to 15 or you might get TORS issues like I did (I'm surprised you're not getting TORS activation now). Make sure to check your throttle cable freeplay first. It should be 2-3mm at the throttle handle. Check the repair manual for procedures.
Edit: Check that the TPS is not defective and check it as per the manual. Internal resistance may be out of spec.
Rodmax
- Feb 18, 2019
- g4t 6c4
found the problem.. don't know how or why but the throttle cable housing was completely unthreaded from its mount point... I screwed it back in checked throttle position (15) 98 full throttle.... took it out for a ride and it is good... simple but why?.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
It happens with vibrations and such or it wasn't tightened properly. At least you found it.
- 6K
