Phazer clutch alignment
Otter
Manitoba
Hello all i was wondering how hard it is to move the phazer engine around for better alignment. My center to center is pretty good but when i was checking the offset i have a bigger gap at the back of the secondary as compared to the front of the secondary.
Regards,
Otter
There must be someone here that has moved the phazer engine around for better clutch alignment?
Otter
Its a good question.I was looking in manual and cant find anything.Seems the Nytro guys can move thiers with the front bolts.I believe its the same bolts that require tightening in some of the recalls on our Phazers.So its a good possibility the adjustment could be off on some.Next question is where do we get alignment tool?
I have an ulmer alignment tool. When i first got my machine everything was bang on. Now my alignment is going out a bit. Iam guess ing maybe the mount bushings are deformaing a bit. So is the excentric bushing that can be turned to bring it back into alignment?
Otter
