yammiebhy
can you use your phazer for about a week or 2 without this sensor?
i was wondering because the wires are worn off of mine, and it will be 2 weeks before i get a new one, and i dont want to stop riding, would it hurt to use her without the sensor?
brad d
- Oct 31, 2011
http://en.wikipedia.org/wiki/MAP_sensor
this? why notfix the wires?
im not too sure why the phaser has two but yes you will need them.
yammiebhy
tried to fix the wires, didnt work. the sensor is no good anymore.
but will it hurt her if i use her without it?
yammiebhy
its the intake pressure sensor, can i use her without it?
will i hurt anything if i use her without it?
According to this post and the issues I would say no dont ride it since seems to make it rich and not worth it.Wait for the part.
http://www.ty4stroke.com/viewtopic.php? ... sc&start=0
brad d
- Oct 31, 2011
yeah it takes readings from that sensor and rpm ant TPS to know how much fuel and spart to have.
does it have two MAP sensors one cor each cly? never seen a motor like that before.
marpolsdofer
I have had it running with out it before. Just brief rides around the yard to get it move. That was a few months ago its been unhooked for a few months becaues the dealer when they did a recall on it (using another chassis give you change to fer things done again) and forgot to hook it back up. Sometimes is hard to start without it sometimes its not.
