snopro442
- Dec 10, 2007
- neenah wi.
- mod 08 nytro, 2-2007 phazers and a 2010 sno pro 500 speedwerx exterminator. new 2014 nytro for towing the snowcoach. 2015 Viper mpi turbo
I trade my 07 phazer fx clicker shocks for a set of fox floats off a 08 rtx phazer, installed them and it sits lower in the front than it did with the clickers, took the shocks in to have them checked out and they are fine, so, are the front ends the same or is the rtx all different???? any help would be great, thanks
yam177
- Aug 14, 2008
- Shoreview MN
- www.jbeurotech.com
The floats are slightly shorter than the Clickers it will help the sled cornor flatter as well
Also depends what pressure you run them at.
snopro442
- Dec 10, 2007
- neenah wi.
set them at 65 psi then installed them, it sits lower then my other 2 fx's.
Thats about where my buddy ran his for pressure I believe.Odd they made them shorter.
marpolsdofer
As we found out this last week at the race. The fo floats that come on the sled or ordered from yamaha are slightly longer the then the one from other sources. As we all know yamaha and diffrent specs then everone els!
