LEE337
I have been getting the Phazer ready for the season and it has developed a very large stumble between 6000 and 8000 RPMS.
I have done the typical things such as drain the fuel and replaced with fresh. Also checked plugs and added some seafoam. None of which seemed to help at all.
I searched the forum but did not find much.
Anyone have any thoughts?
2009 rtx 6500 miles all stock just longer track.
2stroken
I am having a similar issue, mine appears to be at a specific throttle position. I can always gas it and it will smooth out, but if I try to hold steady throttle position(20%) it will get to missing and such. I am looking now to see cost of a new TPS, and the possibility of cleaning it.
LEE337
You're right it seems similar. When you talk in terms of throttle percentage it does seem like that 20-30% maybe even up to 50% at times there is a big stumbling.
2stroken
Here is the part number, 8GC-85885-00-00 from that I have found for a 2007
LEE337
I just found ATV PRO's Misfire thread and I am going to investigate into his findings.
LEE337
Well the phazer is fixed.
Here is what I did:
Checked TPS in diagnostic mode (good)
Removed the tank
Emptied all the fuel
Found another clamp off the exhaust (second time)
Check resistance in the coils (good)
Changed plugs
Cleaned and greased many electrical connections (ECU connections included)
Fresh fuel
Stumbled some at first but then quickly came out of it.
Not real sure root cause but at least it is good now.
Here is what I did:
Removed the tank
Changed plugs
Fresh fuel
2stroken
After changing plugs on mine, it seemed to be better, however with more riding it has seemed to come back. The stumble I have is in such a specific range I am leanin towards a tps. As soon as I change throttle position the sled clears right up and goes.Well the phazer is fixed.
Here is what I did:
Removed the tank
Changed plugs
Fresh fuel
LEE337
Have you checked the TPS for calibration/#'s jumping around in diagnostic mode?
2stroken
I did the diagnostic and it looked like possibly it would jump around from say 22,23,22 on a slow increase, and then say 25,26,25 on a slow decrease. I put some grease on the terms and we will see what happens. On another note, I haven't had to change the filter yet, once the airbox is removed will the oil filter come out the top?
LEE337
If I remember correctly it does.
2008lee
- Apr 21, 2016
- vanderhoof
- 2008 phazer mtx 151
My phazer had a stumble at 5-6000 rpms. It was related to a poor connection on cyl #1 air pressure sensor. An open or short on a air pressure sensor is code 13 cyl #1 and code 25 cyl#2.
ATV PRO #11
- Jan 22, 2011
- Garson, MB, CANADA
- 2014 Yamaha Phazer XTX
I did same thing and issue seemed to creep back through out the riding season last year. To the point of only running on 1cyl. Ran in circles with that stumble thinking same thing that I had her found and fixed. Keep us postedWell the phazer is fixed.
Here is what I did:
Removed the tank
Changed plugs
Fresh fuel
2stroken
So if a code exists, do you get a malfunction light to indicate a code is present?
ATV PRO #11
- Jan 22, 2011
Yes. Usually. Sometimes it'll only blink yellow light and code pop up for a split second then clear itself. If it was there it'll be in memory. You can check that.
2stroken
Thanks, guess I need to become more familiar with my display.
