phaze5
teerex
phaze5 said:teerex be careful with your track i had one come off when iwas 20 hurt likee hell lose your track and your brakes are gone2 i was headed for irrigation ditch at night sled rolled to stop close call i ca still feel it back tunnel got tweaked good be careful looks killer i fixed my road rash with a can o f paint illsee if it holds up before i do the other side
not beeing a US citizen I had to read twice to understand the full meaning
You lost your track at the age of 20?
rfabro
Nobody can read his typing, teerex. No punctuation and all misspelled.
phaze5
yes it ripped off, and rfabro dont read my post 's
teerex
but was the track drilled ?
phaze5
no just studded ripped straight across. i will never drill holes again. remember your sleds a little more hp than before. so if you start hooking up id let off
teerex
A studded track provides brutal traction and probably can be more harmful to the track than drilling. I hope
30000SEK is 4687$ But to get the actual price in USA you have to contact your local distributor.
SharkAttak
teerex said:With these modifications this FX turbo should be fun.... just have to wait some days to test it. All snow rained away this weekend
Drilling track and letting the exhaust come out the easy way:
nice ride
teerex
Did some repairs in may, here are the pics. Cracked exhaust caused by loose exhaust clamp. No I did not install the turbo kit myself
Then modifying the pressure tube with an alu tube replacing the long rubber hose and installing a heat shield in front of the air filter.
Finally re-winding the heat protection that ended up in the air filter as fibredust because of loose clamps.
ak
^ Did you install new clamps or did you weld in the mcx flex joints?
And where the exhaust cracked by the hanger was it caused by the bolt
being loose?
being loose?
teerex
No I did not install new clamps. I guess it will not loosen again when tightened to the specified torque.
Someone must have forgotten that last year
No the bolt at the hanger was not loose. But maybe the pipe cracked because of stress or poor construction.
ak
Ok you re used your clamps, When I had mine tore apart last year one of the clamps was loose also, I guess its a good Idea to check them once in a while. Thanks for posting the pic.
teerex
My clamp was not only loose, the screw was completely gone...
fraser.911
- Oct 3, 2008
cannondale27 said:There are a few.Yes its hard and costs alot of time and $.Thats why we all dont have them.
speed costs money son how fast you wanna go???
