SharkAttak
is just the pins and nut's they re-place on re-call?
00ranger
is the fan a recall? looking at a 07 phazer gt... wondering if the fan is free yamaha update or not thanks
tkuss
The Fan is not a recall.
There are two bulletins for '07 Phazers but only one is a recall. It's for the steering idler arm nuts, collars and clevis pins.
Parts replaced:
2 - Collars
2 - Nuts
5 - Clevis pins (new parts are cotter pins - two different part numbers)
The other is a "Quality Assurance" Technical Bulletin and it's covered by warranty.
Parts installed:
3 - Metal braces for the black plastic cover over the idler arms to keep snow from squeezing in and pushing past the cover.
2 - Rubber blocks mounted on the front corners of the airbox to seal against snow.
2 - Rivets with backing washers. They replace the original rivets holding two clips inside the airbox. The original rivets can break and get sucked in to the engine.
PLUS retorque the front left motor mount to a higher torque. Some were coming loose.
Recall or not, it's all covered by warranty. Save some time and have everything done at once.
Parts replaced:
2 - Collars
2 - Nuts
Parts installed:
tonymanto
okay, i know this is probably mentioned somewhere else in the forum, but since everyone keeps asking the same questions here..... i just installed an excell exhaust on my sled. can i still bring it in for the recall work?
Tonymanto-- You sure can, I have different exhaust on mine and the tunnel is closed off. They even complemented on how it looks. You souldn't have any problems.
SharkAttak
thanks
DKBrigs27th
1049 said:There are two bulletins for '07 Phazers but only one is a recall. It's for the steering idler arm nuts, collars and clevis pins.
Parts replaced:
2 - Collars
2 - Nuts
Parts installed:
Is there a place or website that you found this information? Thanks,
Dave
When I looked at the instructions that came with the "kits" at my dealer that is exactly what it said.
viper_chick
- Mar 31, 2005
- Marine City, MI
- Phazer
DKBrigs27th said:1049 said:There are two bulletins for '07 Phazers but only one is a recall. It's for the steering idler arm nuts, collars and clevis pins.
Parts replaced:
2 - Collars
2 - Nuts
Parts installed:
Dave
There is a Technical Bulletin section in the forum and the bulletins are posted here:
http://www.ty4stroke.com/viewtopic.php?t=46606
cdsgraphic
viper_chick said:DKBrigs27th said:1049 said:There are two bulletins for '07 Phazers but only one is a recall. It's for the steering idler arm nuts, collars and clevis pins.
Parts replaced:
2 - Collars
2 - Nuts
Parts installed:
Dave
Sorry, but only users granted special access can read topics in this forum.
SharkAttak
so there's one or two re-call's
Vmax4
- Apr 18, 2003
- Orondo, WA
- 2010 FXNytro MTX 162 SE with a 270 hp MCX Turbo and assorted goodies!
Zook, what dealer did you go to in NH? Just curious. I bought a fan for a phazer, because Yamaha would not give me one, claiming there was no problem. They told me the dealer could do it, but that the dealer would not be repaid for the parts. It would be the good will of the dealer. That was a call I had with Yamaha last winter.
Vmax-- I went to a dealer in Concord, Freedom Cycle. They called me lastnight and tolt me that my idler wheels were in. I will pick them up tonite. Lots of luck. BTW what did the fan cost you.
Bruce--
Bruce--
Tturbo
Man you guys gotta pony up and lay into your dealers. There is a number of issues that should be tended to by them. Some of them are safety issue others are not.
I am in south western Canada and my dealer although needing some poking and proding has been great. He has done all 3 recalls. He is replacing the rear bracket for free, and has offered to sell me the side deflectors, and a bunch of other parts for cost. My Mtn Lite came with a fan. If you were too cheap to pay for a model that came with a fan to start with then you should have to pay for it in the end. That is not worthy of warranty or recall.
The dealer here respects that customer service has to go beyond the big transaction (purchase of new sled) :ORC
These dealers can give you this stuff and should if you have to pay a little thats fine but still should be done. You got to force the conversation thou and be persistant. Good luck
