terret725
fronts are diff. the viper has a clevis mount "fork" on one side and an eye on the other. the phazer has an eye on both.
Srxspec said:I would call them coupler blocks. They actually replace the 3-position torsion spring blocks on the rear swing arm. They are a 4-position billet aluminum block. The part number is 210-510 if you go into snowmobile products and then do a search it should come up.
RedPhazer said:Sorry I didn't get a chance to follow up on my findings from the Saggy Butt thread. Anyhow, I pulled the skid back out this weekend. I installed new hyfax and installed the new bushings. The bushings I pulled out and replaced from the front mounting point of the skid to the tunnel were in pieces. Everything is now put back together and properly torqued and all seems well!
BTW, if you are having the problem with the saggy rear suspension it's obvious when you compare it to a new model. So... if they have a new phazer on the showroom floor, it should be easy to make your case!
I'm also glad to hear that it's the rear shock that matters most since I just swapped mine out with the fx model and yamaha racer springs!![]()
Regards,
Tom
rhino_live said:1- turf the windshield
2- hand guards
3- Radiator guard
4- mountain bar
5- rear shocks, front ones should be rebuildable the skid shock replace with FX shocks
6- tunnel close like terret said
If i were you I wouldn't put an exhaust, these litte creeps are freeking loud, I had an FMF slip on pipe on mine and it was ridiculus, had to change back to the stocker. as far as the tunnel closure goes a sheet of aluminium cut to size and 6-8 pop rivets should do the job. I'd also look at relocating the guage pod. someone on here has a tutorial for using the stock bracket for this. In my opinion the forth wheel kit is useless unless you're coming down on the rear axle alot or hitting some really nasty terrain.
