phazer wont start
PHAZER MAN
lexington,mi.
hey guys i have a problem and wanted to know if you can help me. last year i flipped my 07 stock phazer and it caught on fire. i put the fire out but it burnt my spedo wire. the sled did start up and i drove it on the trailer. when i got home it would not start so put it away for the year. well its been bugging me so i got it back out and replaced the spedo wire and it still wont start. the dash pod turns on but then reads er-1. the warning light comes on with the temp light on the bottom. then on top the self diagnosis light and coolant light flash.also i dont hear the fuel pump turning on. i did check all fluids and fuses. now i'm counting on you guys. any help i can use it all thanks
could be your ground block in wirering. It is wrapped up in the main wirering harness beside the oil tank. Also try un plugging (cant remember which one) one of the pluga that go into voltage rectifier (LT side next to stering post on top of mach) and turn key and listen for fuel pump to kick on? if yes new rectifier
