Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I am trying to charge my phone in the goggle bag while riding , but inevitably the charge cord becomes un hooked .
Anyone having this issue , and have a solution ?
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Wireless charge with phone secured to it. Or phone secured to small plate on which the charging wire is secured.
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Turn it off ![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
I run the Rocztoys power supply on my Vipers and have never had the cable come out of my iPhone in the goggle bag. I did by 90* cords for them as the regular ones were just a tad tight. Bag keeps phone warm, power supply keeps phone charged, Sena S50 keeps music flowing and Chubby Buttons makes it all work with gloves on.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Yamaha Handlebar bag has a nice pocket on the fwd side of it.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
I’ve always thought carrying a phone main purpose is in case of emergency it is a form of communication. With that in mind the best place for the device is in a pocket on your body. If the off chance something happens to the sled (fire ,submerged) you have the device at your disposal. Even a crash and you can’t move and are separated from machine you could still access it
If the battery does last all day in your pocket you probably time for an upgrade
Knappattack has a good setup to accomplish this, as he answered this question for me years ago. He uses a handlebar mounted cellphone bag with a Qi Charger underneath, which both charges and keeps the phone warm. Hopefully he chimes in.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
I charge my I phone in my google bag never had issues but I do put my phone in my toque before putting in google bag.
turbogts22
- Jan 16, 2021
- Spooner, Wisconsin
- Two 2010 Phazer GT's
I've used a rubber Qi wireless charging tray that cradles the phone really well. I've also had great results just using the USB charge port on the phone, as long as all the pocket lint is cleared out. If there's any crud in there the physical connection becomes unreliable.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I bought a new Iphone brand cord , as I think the current cord is an after market one that doesn't fit as securely as it should .I charge my I phone in my google bag never had issues but I do put my phone in my toque before putting in google bag.
The display charge cord model at the Best Buy store has a 90 degree turn , that doesn't stick straight out , as all seem to do , but also clicks when it is inserted to the phone, to help hold it in . Unfortunately they do not sell this version , as it has security integrated into it , for the store .
The toque will also eliminate , most of the jiggling around for sure .
The cable really shouldn't be pulling out. Look inside the port on your phone, they are notorious for picking up pocket lint which allows the end of the charging cable to not seat properly and fall out easily. I use a small plastic piece to clean out that port once in awhile.
If you want a cheap way to do it, just wrap the cord back up along the edge of the phone, leaving enough slack in the cable that you aren't putting pressure on the port. Secure with a hair or rubber band.
actionjack
- Apr 9, 2005
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Ya i only used the original iPhone cord and I think that putting in toque helps it from bouncing around.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Yes, it works soooo well, and is cheap to accomplish. You can see the live data if you use a flasher, or a trial map on your phone if you prefer too. Pieces can be had from amazon With the Qi charger it charges and heats the phone up as well.
