Pics of Temp Gauge
local 25
Boston mass
I installed my gauge surface mount instead of flush mount.The reason for doing it this way was there is a metal support bar for the new style mirrors that runs behind where the gauge would be if I flush mounted it.Also I did not want to cut the cowl.I used p.v.c pipe for the outer shell of the gauge.it fit the 2 and 1/16 gauge nice and snug. Then i painted it.
That looks awsome. I was going to put a gauge like that on mine but didnt want to cut up the inside of my hood. I'm now going to be looking at doing something like that.
To get the gauge to hold on ,there are 2 threaded studs that stick out of the bottom of the gauge.I drilled 2 holes for them about 1 & 3/4 apart and a hole in the middle of those for the the 3 wires.
GUAGE
Man that looks awesome! I am so glad you posted that I am going to do it your way! :Rockon: :pics:
Sorry I did not take any pics of the back,but its pretty basic .You use a 3/4 wing bit for the center hole and 3/16 drill for the gauge mount studs. Just center the holes in the area next to the speedo .Hope this helps.
