pictures of the reverse gear(s)?
couch
Newfoundland
Anyone have actual pictures of the reverse gears ... put the chain case back together and the position of the little spring between the gears has been bugging me ever since ....
Do the holes in the gears line up for the spring or are they off set ... does the spring fit in the hole on each gear or only one side .... yes its a dumb question but its been bugging me and I figure that I may have to pull the case apart to check.
Spring goes in the hole on both gears. All it does is keep them from rattling (for lack of a better term) back and forth.
That is correct!
