gun nut
I put this on another area, but thought I should start a new topic about it. I would like opinions on the Pioneer wheel kit that drops the idlers down, instead of using larger wheels.
I've only seen it mentioned once on this site.
ryama
- Mar 3, 2009
- Kitchener Ontario
- Sidewinder R-TX
- Kitchener
Thoughts
Second year on the kit and no regrets. I believe spreading the load over the rails with two bolts is just..... better engineering. There is lots of guys running bigger wheels, and have had no issues. But there is also guys who say they have cracked the ear on the rails, from the additional load . Two ways of getting to the same point. Slider's last..... and no cracked rails. I also bought the new Yamaha wheels, with replaceable bearing while I was at it.
gun nut
Thanks ryama. My main reason for the post was that I haven't heard much about them.
gun nut
grubf
- Dec 9, 2008
Just got done installing this kit. I like the way the new brackets lock over the ridges in the slides. The whole idea looks to be to spread out the load a little bit.
dirtysteve
put them on three sleds last year, makes you wish they came with them. 1/2 the amount of hyfax wear
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
I used them work well....sold the machine to user "Ding" he still owns it and can comment
Gun nut, do you have a link for the Pioneer wheel kit? Thanks
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
3 Phase
- Dec 28, 2005
- Nova Scotia
- 2012 Vector LTX
I have both the Pioneer kit and SLP wear pads. My most recent set of slides lasted 12000 km. Prior to this, slides were lasting 500-1500 km.
snowbiscuit
You can't go wrong with kit and use your old wheels....went from bad slide wear, lucky to get 500 miles to now 3000 and a lot to go
70superbee
Been using them for 5000 miles and no problems.
Richie R
Richie R
