Attak wheel kit?
sleddog66
DeKalb IL
First of all, I have searched for this, and it seems that all I can find is pictures of apex with low snow wheel kits. I have a 07 Attak, and I just put the pioneer hyfax extender kit on. This seems like a nice kit. I also have a anti-stab kit in the front. It seems that the entire hyfax area should be much better except for the area between the double wheels, and the rear smaller wheels(right below the pivot). Because of the rail reinforcement in that area, I have not figured out how to add a set of wheels there. Has anyone done this on an attak? what kit? Pictures? Thanks for any replies.
I just put them right behind the rail supports.
My sledders wore near center. Thats where I put mine, easy install and it works.
viper, did you add the yami low snow kit or what? do you have pics? So the rail reinforcements did not cause problems?
sliders. lol
I added mine the same as Apex in the middle rail area only. The front strap is pulled up all the way too. The reinforcements did not cause any problems. You can move the wheel back or forward a couple of inches depending where your wear is on the slider.
