Stone9
- Dec 29, 2010
- Quimby, IA
- 2013 Nytro XTX
I know this topic has been hit 100 times but I hit a washout last season and dropped my left ski right in. Now I have something bent or egged out and I can not tell what it is. I have oilites and grizz gussets. I really doubt the subframe bent with my gussets in and none of my welds cracked. I also checked the bolt hole and it seems to have just a little more play than the other side. But when I tighten everything up that doesn't move.
I am wondering what is more likely to be causing play, the oilites or the bushing that runs thru the a arm. I have looked at them alot over the last couple days but I can not see any signs of stress. Any ideas?
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
a arm bolt holes egged out?
Stone9
- Dec 29, 2010
- Quimby, IA
- 2013 Nytro XTX
No visible egging and when I tighten I can't see the bolt moving just the a arm on the bolt or bushing
Supa Dexta
Where are you seeing, or feeling the play? Thru the bars, or by hand moving a ski?
Stone9
- Dec 29, 2010
- Quimby, IA
- 2013 Nytro XTX
By hand moving the upper a arm with front end lifted
