vx700xtc
I believe Arctic Cat has what is functinally the same as TORS.
REXX
- Jan 5, 2007
With some left hand throttle setups TORS will not work on the left throttle. I ran an RX1 mtn for 4 years and now an Apex mtn for two years. Both with left hand throttles; both with TORS disconnected. The tether in this case is the necessary safe solution.
REXX
'07 APEX mtn SE turbo
REXX
ApexerER
The TORS is a great idea and I would never trade it for a tether. My XCR had a similar set up. My Mach Z did not and I was coming in to a corner hot let of the throttle and it was stuck wide open. Let me tell you that KILL SWITCH is hard to find when you are taking a 25 MPH corner at about 80. I am lucky I didn't get killed. The tether sure didn't help me but TORS would have........I sold the Mach and bought the XCR 800 for that reason.
rightarm
REXX said:With some left hand throttle setups TORS will not work on the left throttle. I ran an RX1 mtn for 4 years and now an Apex mtn for two years. Both with left hand throttles; both with TORS disconnected. The tether in this case is the necessary safe solution.
REXX
T.O.R.S works for me
Shootinstick
I don't see that one replaces the other. I would like to see both, but definitely don't want a tether in place of TORS. The tether I see as a last ditch safety, Works after you come off the sled. The TORS hopefully will shut the sled down due to a throttle failure before I come off. Tether will work if I come off for any reason, not just a throttle problem.
rightarm
ragerider
tether
When I was around 15 I rode an 88 skidoo formula mx which had the tether basically on the steering shaft. my family was trail riding I had a map bag on my sled I went to adjust my hand warmers which moved the mapbag pulling the tether and shutting off the sled. Well I was young and told my dad that when I adjusted the warmers the sled shut off we thought it was electrical. We borrowed a tow rope and pulled it 20 miles to the truck. When we got back ready to load up I removed the map bag and saw the terther was out, pluged it back in and rode it on the trailer and never had anymore trouble!!!!
Dano
Who wants to hold on to the end of a tether when they roll off their sled and watch it hit a tree from the throttle stuck open? lol I think the last tether for Yamaha was 1983 if I remember right. Thank God for TORs now. The only time I seen a need for a tether was ISR racing rules to pass tech.
Yeah skidoo has a neat setup with a chip in the tether, but I never ever seen anybody connect the damn thing. The anti theft thing all sounds good, but doo builds them light enough to throw the whole sled in the back of a pickup truck in seconds, only to be reincarnated into ebay.
Dan
Dan
rightarm
Yamaha could easily install a tip over switch that shuts the motor down when rolled like on there 4-stroke watercraft.
