Zakre said:smoothride said:How do you tighten the belt an loosen it to get it on an off.
I would bet the top pulley is eccentric so you rotate it to tighten the belt up, essentially the hole in the pulley is not in the middle so when you rotate it will take up the slack in the system then you tighten the pulley down to keep it all in place.
Its hard to tell from the picture but it looks that way to me.
Heritage said:This is not new polaris designed tech!!! Havent u guys heard of CMX??? They have had belt drives for years....where the heck have u guys been??
And for the guy who asked...i think u can get a belt drive for an apex from cmx.
Roadrider said:Zakre said:smoothride said:How do you tighten the belt an loosen it to get it on an off.
Are you saying the pulley is going to run out of round from the shaft center?
The whole shaft could be adjusted in an arc but not just a pulley.
