snowracer1000
I am thinking of powder coating my rails, rear skid parts, a arms and spindles. The first question is will good powder coating hold up in the rails or is it a waste of money. Second it's a black xtx polished tunnel i am thinking spindles in black, a arms and rear pieces in the candy red like the 06 apex arms. What do you guys think?
arteeex
Is there a special someone you're trying to impress?
snowracer1000
my self I like my stuff to be custom and kick #*$&@.
enticeraised
Would look nice but fairly costly...
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
The coating should hold up real well on the rails, assuming they are prepped right by the coater.
Of all the coating I had done on my trailing arm sled, the radius rods took the biggest beating and even then there was only minor surface chipping(not right through to the metal). The R Rods did develop a little 'sand blasted' look but could have probably been polished up. I had it for two seasons like that. All the other coating was fine.
snowracer1000
I have a local shop that will do it all for pretty cheap and they do good powder coating i have sent alot of stuff to them over the years thanks for the help
SSX600
- Feb 13, 2010
- Richland Center WI
- 2010 Nytro XTX, 1997 Mtn Max 600, 1998 SSX600, 1975 SM292F, 1987 Inviter
snowracer1000 said:I am thinking of powder coating my rails, rear skid parts, a arms and spindles. The first question is will good powder coating hold up in the rails or is it a waste of money. Second it's a black xtx polished tunnel i am thinking spindles in black, a arms and rear pieces in the candy red like the 06 apex arms. What do you guys think?
I powdercoated the rails on the 2 stroke I put together last summer and they held up extremely well this winter and still look good. I also like to have some things custom to my liking I also just bought a used 2010 XTX Black on Black and I am thinking of ways to personalize it to my liking. heres a picture of my suspension I put together for the SSX600
welterracer
bitchnblue09
Just make sure that they are balasted or ruffed up really well, and I would suggest clear coating them, or for sure you wont get more than 2 years out of them, if that, I worked in a powder coating shop, and its over rated im my opinion, but it does depend on the prep. But for sure clear coat the parts, I have seen both, and the parts that were clear-coated lasted way longer, and they did not rust or fade..... Just my 2 cents.
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
welterracer said:as long as the rails get blasted first to insure good adheasion.. the powder coating should hold up excellent..
Here is a picture of the red you want..
Nice work!
