Anyone know which wire the butt connector goes to?I assume it is one of the TPS wires?
07STI_Matt
im not sure, i just got the pcIII but havent installed it yet. did you get the expansion hub?
No.Thanks
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Yellow! cannondale, I will give you a call shortly.
Awesome! Thanks
kodak
cannondale
HI cannondale I was just looking at the power commander on the ulmer site and dropped him an email wondering if it would be any good for my phazer mtx . can you let us know what your experience with it turns out . Also on the ulmer sit under skis there were berkstrom ski savers to help cure darting do you know if they fit stock mtx skis. thanks good luck with power commander.
Will do.I have run the PC's on quads and they pretty much do anything you could want.Should be same on here.
rotax454
Power Commander update
Ok Cannondale, Give us an update. How goes your Power Commander addition? Tuning, performance, fuel mileage, etc.
I know my fuel mileage is better with Ulmers stock map.I havent felt or observed any difference power wise.I gave up running the pipe because of noise.I did see some power gained by tuning with pipe on.But not sure what to do for power gains now.Still planning to try dual R1 exhausts and Ulmers Airbox so at that point should have a real need for the PCIII.Right now I am totally stock and it has always and still runs great with it on or off.
rotax454
You said Ulmer stock map. Do you mean his program is identical to the factory stock map? Or his custom mapping designed to be used on a complete stock Phazer motor?
His map designed for a stock motor.Its leaned out a bit in a few spots.No issues at all with it and like I said does deliver better MPG.I would assume it must make a little power since it didnt hurt power or cause it to run hot.Just cant notice it.
Weapon X
So can a map be made for for a modded airbox and an FMF muffy ?
tatalover78-2
i thought Ulmer had two maps for the PCIII. One with a stock setup and a second for an airbox / pipe mod
He does.I only got the one for stock motor.Since when I first put PCIII on I was stock.
