Ringold24
- Feb 13, 2015
- Ramsey MN
- 07 Yamaha Attak GT
Im looking for a little help considering my lack of knowledge on electrical systems. I would
Like the LED’s to turn on/off with ingition switch. Same as headlights basically. Where should I tap in to the power source?
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
I wired mine in separate so I could use them as parking lights if we stopped along the trail with the sled shut off. Just my 2-cents worth
You can wire them up to the headlight circuit. They will only be on when the sled is running.
You can find the wires you need in the left footwell on the 5 bladed headlight relay
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
Does the apex have the 12v outlet? Can splice into there.
Ringold24
- Feb 13, 2015
- Ramsey MN
Which wire is “hot” Green or white/black?Does the apex have the 12v outlet? Can splice into there.
Ringold24
- Feb 13, 2015
- Ramsey MN
Green=ground
White/black=hot??
White/black=hot??
Ringold24
- Feb 13, 2015
- Ramsey MN
Got it done. Tapped into 12v accessory outlet. Works great. Thanks fellas
super1c
Moderator
- Apr 10, 2010
Glad ya got it. Don’t have a apex so wouldn’t have know which is which. This is where I wired mine in on my viper.Which wire is “hot” Green or white/black?
