polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Ted Jennety Clutching, jetting, air box mod.
Arctic Cat Z1 Turbo 128" Rear Suspension
128" Hacksaw 1" track.
Heated seat
What should the side clearance be between the belt and the sheave of the primary. If I remember on my Polaris sleds we would shoot for 10 thousands.
I have 600 miles on my belt on my 05 RX1. The sides or the belt are starting to go with some threads coming out. I did not measure, but the clearance between the belt and primary sheave is huge. I am sure it is from the belt being worn. I did not notice any performance difference.
Also the bottom of my primary sheaves have a groove in them. It was like that when I bought the sled used. My friends 03 RX1 has the same problem. Anything to worry about?
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
- www.yamaheater.com
- 2007 Attak - LOVE my sled!!!
The side belt clearance is pretty large from the factory. Mine was near 1/8"
It makes the engagement kinda "grabby".
Had a friend make me some spacers/washers that go under the mounting bolt to adjust the belt deflection (clearance).
I made it .015"
(Allen Ulmers(Ulmer Racing) great idea! Allen is great!)
The "groove" is also from the factory. it is normal.
It is actually more like a "bulge" down low and just above it, it looks like a groove.
The clutch is coated with some type of "hardcoat".
It is a slightly grey color, if you have no shiney aluminum showing, it's still the hardcoat and you have little to no wear.
Hope this helps!
I made it .015"
Hope this helps!
black john
belt side clerance
the proper way to ajust belt side clearance on a yamaha clutch with out screwing up your wight under tuck is to use differnt c clips. i have only seen haulk selling these but if you have some time and take down tools you can do like i do and make your own. taking the side clerance down is like free hp i like to run no more than .020 and .015 if i can get it. this way i can still play with the tuck under if i need to with out buggering up my shift patern.
polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Heated seat
Thanks for the info.
I will get a new belt and ck the clearance. If is is out of spec then we will break it down and adjust.
black john, what is tuck under?
Bruce
Bruce
